Holas amigos..
Buscando en la red encontre esta pagina con bastante información para los 960, en version PDF,
http://caunter.ca/volvo960/ [ok]
Encontraran todo esto
http://caunter.ca/volvo960/cv14797.pdf">2.9l 6cyl
http://caunter.ca/volvo960/tt14799.pdf">engine vin ID
http://caunter.ca/volvo960/xd14800.pdf">AC compressor refrigerant checking
http://caunter.ca/volvo960/ex14801.pdf">AC compressor servicing
http://caunter.ca/volvo960/xg14802.pdf">AC heater system automatic
http://caunter.ca/volvo960/es14803.pdf">AC system specs
http://caunter.ca/volvo960/jk14804.pdf">air bag restraint system
http://caunter.ca/volvo960/vp14805.pdf">alternator and regulator
http://caunter.ca/volvo960/cc14806.pdf">anti lock brake system
http://caunter.ca/volvo960/ce14807.pdf">auto trans diagnosis AW-40
http://caunter.ca/volvo960/ry14808.pdf">model specific emissions info for all 94 volvo models
http://caunter.ca/volvo960/hd14809.pdf">brake system
http://caunter.ca/volvo960/oc14811.pdf">fluid service intervals and specs
http://caunter.ca/volvo960/cm14812.pdf">cooling system specs and electric diagrams
http://caunter.ca/volvo960/hc14813.pdf">cruise control
http://caunter.ca/volvo960/ip14814.pdf">throttle and ignition adjustments
http://caunter.ca/volvo960/bl14815.pdf">drive axle
http://caunter.ca/volvo960/fo14816.pdf">drive belt routing
http://caunter.ca/volvo960/ic14817.pdf">engine cooling fan electric diagrams
http://caunter.ca/volvo960/mh14818.pdf">engine diagnostic tests with out codes
http://caunter.ca/volvo960/zg14820.pdf">engine diagnostics with codes FLASHING LIGHT
http://caunter.ca/volvo960/pv14819.pdf">fuses and circuit breakers
http://caunter.ca/volvo960/pr14821.pdf">engine symptom diagnostics
http://caunter.ca/volvo960/vj14822.pdf">instrument panel
http://caunter.ca/volvo960/wb14823.pdf">resistance range charts for all engine sensors on all 94 models
http://caunter.ca/volvo960/hd14824.pdf">engine wiring diagrams for all 960 940 850 models in 1994
http://caunter.ca/volvo960/fe14826.pdf">vacuum diagrams for 940 and 850
http://caunter.ca/volvo960/xw14827.pdf">960 maintainance info for OBD1 and OBD2
http://caunter.ca/volvo960/cg14828.pdf">maintenance reminder light reset procedures for 90-95 740 760 940 960 and OBD2
http://caunter.ca/volvo960/py14829.pdf">power mirrors
http://caunter.ca/volvo960/xn14830.pdf">EGR function test 89-95 ALL
http://caunter.ca/volvo960/vz14832.pdf">power windows
http://caunter.ca/volvo960/ug14834.pdf">schedule service
http://caunter.ca/volvo960/nq14836.pdf">starter motor
http://caunter.ca/volvo960/pn14837.pdf">steering column
http://caunter.ca/volvo960/mn14838.pdf">steering column switches
http://caunter.ca/volvo960/ej14839.pdf">steering system power rack and pinion
http://caunter.ca/volvo960/vm14840.pdf">sun roof power
http://caunter.ca/volvo960/bm14842.pdf">suspension front
http://caunter.ca/volvo960/jl14843.pdf">suspension rear
http://caunter.ca/volvo960/rp14844.pdf">transmission removal and installation LITTLE INFO
http://caunter.ca/volvo960/dl14845.pdf">transmission servicing LITTLE INFO
http://caunter.ca/volvo960/qx14846.pdf">wheel alignment specs
http://caunter.ca/volvo960/aj14847.pdf">wiper washer system
Velez
Velez
