coches que comparten el mismo motor que S40 1.6D 2005-
Ivan Liria
23 Dic 2012
1.584
5
SI ESTO ES CIERTO: PUES ES ÚTIL Y SI NO: ME LO DECÍS Y ELIMINO
CITROËN
ModeloAño const.VersiónAño const.kw/cvccCódigo de motor
BERLINGO20081.6 HDi 75200855/7515609HT (DV6BTED4); 9HW (DV6ETED)
20081.6 HDi 90200866/9015609HX (DV6ATED4)
20081.6 HDi 110200880/10915609HZ (DV6TED4)
BERLINGO (MF)19961.6 HDI 75 (MF9HW)200555/7515609HW (DV6ETED); DV6B
19961.6 HDI 90 (MF9HX)200566/9015609HX (DV6ATED4)
BERLINGO Caixa20081.6 HDi 90201068/9215609HP (DV6DTED)
20081.6 HDi 75200855/7515609HT (DV6BUTED4); 9HW (DV6ETED)
BERLINGO Caixa (M_)19961.6 HDI 75 (MB9HW)200555/7515609HW (DV6ETED); DV6B
19961.6 HDI 90 (MB9HX, MC9HX)200566/9015609HX (DV6ATED4)
C2 (JM_)20031.6 HDi200580/10915609HZ (DV6TED4)
C3 (FC_)20021.6 16V HDi200580/10915609HZ (DV6TED4)
20021.6 16V HDi200566/9015609HX (DV6ATED4)
C3 II20091.6 HDi 90200966/9015609HX (DV6ATED4)
C3 Picasso20091.6 HDi200980/10915609HZ (DV6TED4)
20091.6 HDi200966/9015609HX (DV6ATED4)
C4 (LC_)20041.6 HDi200466/9015609HX (DV6ATED4)
20041.6 HDi200480/10915609HY (DV6TED4); 9HZ (DV6TED4)
C4 Coupé (LA_)20041.6 HDi200466/9015609HX (DV6ATED4)
C4 Grand Picasso (UA_)20061.6 HDi200680/10915609HY (DV6TED4); 9HZ (DV6TED4)
C4 Picasso (UD_)20071.6 HDi200780/10915609HY (DV6TED4); 9HZ (DV6TED4)
C4 três volumes20061.6 HDi200680/10915609HY (DV6TED4); 9HZ (DV6TED4)
C5 (RC_)20041.6 HDi (RC8HZB)200480/10915609HY (DV6TED4)
C5 (RD_)20081.6 HDi200880/10915609HZ (DV6TED4)
C5 Break (RE_)20041.6 HDi (RE8HZB)200480/10915609HY (DV6TED4)
C5 Break (TD_)20081.6 HDi200880/10915609HZ (DV6TED4)
JUMPY20071.6 HDi 90200766/9015609HU (DV6UTED4)
JUMPY Caixa20071.6 HDi 90200766/9015609HU (DV6UTED4)
XSARA PICASSO (N68)19991.6 HDi200480/10915609HY (DV6TED4)
19991.6 HDi200566/901560-
FIAT
(por propuesta de ​
Lecar 88​
y gracias a su investigación FIAT queda descartado)​
Modelo Año const.VersiónAño const.kw/cvccCódigo de motor
SCUDO (270_)20071.6 D Multijet200766/9015609HU
SCUDO Caixa (270_)20071.6 D Multijet200766/9015609HU
SCUDO Camião de plataforma/chassis (270_)20071.6 D Multijet200766/9015609HU
FORD
C-MAX20071.6 TDCi200766/901560GPDA; HHDA; HHDB
20071.6 TDCi200780/1091560G8DA; G8DB; G8DD
C-MAX II20101.6 TDCi201070/951560T3DA; T3DB
FIESTA V (JH_, JD_)20011.6 TDCi200466/901560HHJA; HHJB
FIESTA Van20091.6 TDCi200966/901560HHJC; HHJD; HHJE
FIESTA VI20081.6 TDCi200866/901560HHJC; HHJD; HHJE
20081.6 TDCi200855/751560HHJF; UBJA
FOCUS C-MAX2003-20071.6 TDCi2003-200780/1091560G8DA; G8DB
2003-20071.6 TDCi2005-200766/901560HHDA; HHDB
FOCUS II (DA_)20041.6 TDCi200480/1091560G8DA; G8DB; G8DD; G8DE; G8DF
20041.6 TDCi200566/901560GPDA; GPDC; HHDA; HHDB
FOCUS II Combi (DA_)20041.6 TDCi200480/1091560G8DA; G8DB; G8DD; G8DE; G8DF
20041.6 TDCi200466/901560GPDA; GPDC; HHDA; HHDB
FOCUS II três volumes (DA_)20051.6 TDCi200566/901560HHDA; HHDB
20051.6 TDCi200580/1091560G8DA; G8DB; G8DD; G8DE; G8DF
FUSION (JU_)20021.6 TDCi200466/901560HHJA; HHJB
MAZDA
3 (BK)2003-20091.6 DI Turbo2004-200980/1091560Y601
3 três volumes (BK)2000-20091.6 DI Turbo200480/1091560Y601
MINI
MINI (R56)2006Cooper D200780/10915609HZ (DV6TED4)
MINI CLUBMAN (R55)2007Cooper D200780/10915609HZ (DV6TED4)
PEUGEOT
1007 (KM_)20051.6 HDi200780/10915609HZ (DV6TED4)
206 CC (2D)20001.6 HDi 110200580/10915609HZ (DV6TED4)
206 Hatchback (2A/C)19981.6 HDi 110200480/10915609HY (DV6TED4); 9HZ (DV6TED4)
206 SW (2E/K)20021.6 HDi 110200480/10915609HZ (DV6TED4)
207 (WA_, WC_)20061.6 HDi200666/9015609HX (DV6ATED4)
20061.6 HDi200968/9215609HP (DV6DTED)
207 CC (WD_)20071.6 HDi200780/10915609HZ (DV6TED4)
207 SW (WK_)20071.6 HDi200766/9015609HX (DV6ATED4)
207 Van20071.6 HDi200766/9015609HX (DV6ATED4)
300820091.6 HDi200980/10915609HZ (DV6TED4)
307 (3A/C)20001.6 HDi 110200480/10915609HY (DV6TED4); 9HZ (DV6TED4)
20001.6 HDi200566/9015609HV (DV6ATED4)
307 Break (3E)20021.6 HDi 110200480/10915609HY (DV6TED4); 9HZ (DV6TED4)
20021.6 HDi200566/9015609HV (DV6ATED4)
307 SW (3H)20021.6 HDI 110200480/10915609HY (DV6TED4); 9HZ (DV6TED4)
20021.6 HDI 90200666/9015609HV (DV6ATED4)
308 (4A_, 4C_)20071.6 HDi200766/901560-
308 SW20071.6 HDi200766/9015609HV (DV6ATED4); 9HX (DV6ATED4)
20071.6 HDi200982/11215609HR (DV6C)
407 (6D_)20041.6 HDi 110200480/10915609HY (DV6TED4)
407 SW (6E_)20041.6 HDi 110200480/10915609HY (DV6TED4)
500820091.6 HDi200980/11015609HZ (DV6TED4)
EXPERT Caixa (VF3A_, VF3U_, VF3X_)20071.6 HDi 90200766/9015609HU (DV6UTED4)
EXPERT Camião de plataforma/chassis20071.6 HDi 90200766/9015609HU (DV6UTED4)
EXPERT Tepee (VF3V_)20071.6 HDi 90200766/9015609HU (DV6UTED4)
PARTNER Caixa20081.6 HDi200855/7515609HT (DV6BTED4)
20081.6 HDi200866/9015609HX (DV6ATED4)
PARTNER Caixa (5)19961.6 HDi 75200655/7515609HW (DV6BTED4)
19961.6 HDi 90200666/9015609HX (DV6ATED4)
PARTNER Combispace (5F)19961.6 HDi 90200666/9015609HX (DV6ATED4)
PARTNER Tepee20081.6 HDi200855/7515609HT (DV6BTED4)
SUZUKI
SX4 (GY)20061.6 DDIS200766/9015609HX
VOLVO
C3020061.6 D200680/1091560D 4164 T
S40 II (MS)20041.6 D200581/1101560D 4164 T
S80 II (AS)20061.6 D DRIVe201080/1091560D 4164 T
V50 (MW)20041.6 D200581/1101560D 4164 T
V70 III20071.6 D201080/1091560D 4164 T
estoy por asegurar que los fiat multijet no son del grupo PSA....
Si justo es lo que hiba a decir,, Confirmado que Fiat multijet no comparte tecnologia con PSA... Lo de Mini creo que son los de la epoca Renault
respecto al mini, a partir del 2007 montó motores PSA . Copio y pego de la wikipedia:
Luego de la reestilización de 2007, todos los motores fueron reemplazados. Los gasolina fueron desarrollados en conjunto por BMW y el Grupo PSA Peugeot-Citroën, y tienen cuatro válvulas por cilindro y distribución variable. El "MINI One" incorpora un motor de 1.4 litros de cilindrada de inyección indirecta y 75 ó 95 CV. Los "MINI Cooper" y "MINI Cooper S" poseen un 1.6 litros, el primero con inyección indirecta y 120 CV, y el segundo con inyección directa, turbocompresor y 184 CV. El Diesel es de origen PSA Peugeot-Citroën y tiene 1.6 litros de cilindrada, inyección directa common-rail, intercooler y cuatro válvulas por cilindro; desarrolla una potencia máxima de 90 CV ("MINI One D") ó 109 CV ("MINI Cooper D"), según si el turbocompresor es de geometría fija o variable.
MINI - Wikipedia, la enciclopedia libre
Buenas, magnífico aporte.
A mí si que me parece interesante, porque viendo las averías de esos coches, podremos saber de los nuestros.
Falta el Volvo S60 Drive.
